Bushing question Would worn out suspension bushings (mainly the torque arm and control arms) cause alot of squeaks and rattling going over minor bumps, or is something else wrong. I've checked all the bolts and everything is tight to spec, so nothing is loose persay... any help would be appreciated. |
certainly would especially since the camaro has no provisions to grease the chassis. |
Did yours ever make a god aweful squeak when you took off from a light and whenever you shifted from 1st to 2nd? |
Originally Posted by jsteele90
(Post 9068628)
© 2024 MH Sub I, LLC dba Internet Brands
