what springs to go with????
hey im having a really really hard time picking what lowering springs to go with i have a 99 camaro ss with the 1LE suspension and i dont know if i wanna go with the pro kit or the sportline kit....im more thinking towards the pro kit just because i dont know how low i can go due to the 315's in the back any help would be great thanks
I'm not a fan of Eibachs from experience. How much do you want to lower it? I'm planning on either Hotchkis or BMR based on my own desires. Hotchkis keeps it like stock as far as ride goes, don't know a ton about BMR, but their rear spring rates start at where the Hotchkis stop, so BMR's are stiffer in the rear.
i dont know much about other springs thats the only reason im leading to go with eibach springs... ive heard the 1LE is a great set up and i have no problem with the way it handles and feels i just cant stand how my car looks like a 4x4 haha its seems that since its white it looks even taller
Strano springs (stranoparts.com) are specifically made with handling in mind, and have excellent street manners. Sam Strano designed them from his experience auto-xing (and winning).
And since you have a 1LE car you have the Koni DA shocks, so all you need(its not 100% required though) to go with the springs is an adjustable panhard bar to re-center the rear end after being lowered.
LS1TECH Sponsor
FWIW, not all Eibach's are the same.... I still use some, and some are among the best alternatives to mine. Some suck. I'm not going to get into semantics here, just wanted to let you know that not all Eibach's are created equal or are subject to "sag" or lack of spring rate issues.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
thanks everyone for all the info soo far im trying to look beyond the eibach springs... the stranos are a 1.25" drop tho.. would i notice that much of a drop? and would i still want to keep the koni shocks that came with the car from fatory or should i look into changing them too?
LS1TECH Sponsor
Yes, you'll notice a difference.
__________________
Here are some before and afters:
LS1TECH Sponsor
You know, I sell Hotchkis too (one of the brands we carry). I could have discussed those with you, as well as other options..... They do look pretty low in front, and that's one reason I tend to not use them a lot because they are sometimes hit and miss on thigns like height.
__________________
jess
LS1TECH Sponsor
Again, if you can't wait for mine, I'd urge folks to call me to discuss other options. They do exist. And while some suck and I'll tell you that, some are pretty good alternatives to my springs, if not great or quite equal to IMO. But I'd rather discuss the options and get you as close as we can if you can't wait, then just bail to any old spring set.
__________________
Well, Sam, I guess I need to call you up. Tried this AM, but I'm not sure what timezone your in. I don't mean to come across as arguing with you, I guess I just can't believe there isn't really a good set of "other" springs, but you've more than done your own R&D. As I said to someone else, you can't expect "good" results on a low dollar budget.
