i know an adj. panhard bar is good but is it going to be needed with only 9.5s in back? stock wheels are only 9s so i dont know if itll make enough of a difference that ill need one.
It is used to center your rear, left to right. Check your current alignment to see if they are the same. Mine was shifted to toward the passenger's side by 13/16". It is now perfectly centered.
I needed it because of the offset on my Fikse rims (9.5" 275/40/17) puts the rims right out to the edge. I also had to roll the rear fenders as it was eating into my tires.
