adjusting PHB for new rims
i just got new rims for my car and moved up from 17 inch to 18 inch rims. the tire is still a 275 width. do i need to adjust the PHB or no? Thanks
From wiki:
"A plumb-bob or a plummet is a weight with a pointed tip on the bottom that is suspended from a string and used as a vertical reference line. This instrument has been used since the time of the ancient Egyptians by bricklayers, masons, and carpenters to ensure that their constructions are "plumb", or perfectly upright. It may also be used in surveying to sight a point on the ground that is not readily visible. Small plumb bobs are included in the kits of various instruments such as levels and theodolites. They are used to set the instrument exactly over a fixed datum marker, prior to taking fresh readings."
With the f-body, follow this to center the rear end:
http://www.bmrfabrication.com/INSTALL/F-BODY_PHR.pdf
