New Trans Mount Now Vibration
Old 05-01-2008, 02:07 PM
Restricted User
Zero4488's Avatar
Exclamation New Trans Mount Now Vibration
Alright....So I just put the Prothane tranny mount in my car, took it for a test ride and notice I'm getting a noticable vibration at anything over 2000rpms. Is this normal for this mount? My biggest question is if the car is safe to drive...Or if I some how managed to do something wrong.
Old 05-01-2008, 03:17 PM
SOMbitch's Avatar
Yes it's normal. I know of a few who could not tolerate it and went back to stock.
Old 05-01-2008, 04:08 PM
Black02SLPSS's Avatar
It will get better when you get more miles on it. Do you have poly motor mounts too?
Old 05-01-2008, 04:15 PM
djsanchez2's Avatar
^^^ Yup mine only did it for ~100miles.
Good question. Did you do the poly motor mounts? You might wanna consider that in the near future, as going with poly trans-rubber motor mounts will put undue stress on the bellhousing risking cracks.
Old 05-01-2008, 04:26 PM
Restricted User
Zero4488's Avatar
Alright...thanks for the input everyone....I plan on doing the poly motor mounts when I do my K-Member....
Old 05-01-2008, 04:32 PM
hpjunky98's Avatar
Ya the vibration is kind of annoying at first, but now i don't even notice it.
Old 05-01-2008, 05:06 PM
Restricted User
Zero4488's Avatar
It's been about 4 hours and I'm already getting used to it...
Old 05-01-2008, 06:21 PM
leadfoot4's Avatar
I could be wrong, but aren't the poly tranny mounts a little "taller" then the OE rubber ones? If so, wouldn't that effectively alter the pinion angle, and in turn cause some vibration?
Old 05-01-2008, 06:49 PM
jsteele90's Avatar
where do u get a factory rubber trans mount? besides the dealer?
Old 05-01-2008, 07:06 PM
cookba's Avatar
autozone, napa, car quest, kragen....................
Old 05-01-2008, 07:30 PM
djsanchez2's Avatar
^^^ I've had trouble finding a rubber one for 1998-2002. The only one's i could find were listed as the LT1 T-56 mount. I know it's the same but, if the parts store has a hard time finding one, ask them to look for that one.
Old 05-01-2008, 10:22 PM
Restricted User
Zero4488's Avatar
I checked the pinion angle and all is well....so it's not that....
Old 05-01-2008, 11:43 PM
99Bluz28's Avatar
If you grind down the preload bumps on the mount most of the vibration will go away. I ground down the preload bumps on my poly mount over 5yrs ago, And I've never had any problems with it .
Old 05-02-2008, 12:00 AM
rich Z's Avatar
That's with the ES mount not the Prothane.
Old 05-02-2008, 12:17 AM
99Bluz28's Avatar
No preload bumps on the Prothane ?....My bad!
Is it better than the E.S. mount?
Old 05-02-2008, 01:11 PM
Restricted User
Zero4488's Avatar
I'm noticing a huge difference with this mount. Even though I have the vibration now, the weight transfer in my car is a whole lot better. Instead of jus the drive train torquing the whole car squats and goes....
