Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Chevrolet Camaro or Pontiac Firebird Steering & Suspension Guides
- Camaro How to Replace Ball Joints<br>Step by step instructions for do-it-yourself repairs.
Removing / Replacing lower ball joints...
So after installing the Konis/Springs, Sway bar endlinks and bushings and new upper ball joints...I noticed (duh!) my lower ball joints are a mess (boots torn, grease coming out etc).
I have some new ball joints coming..
Any tips/tricks getting the old ones out and new ones in? The Service manual shows them to be press in/press out. I figure getting out -- hammer if necessary, but getting in?
Should I buy a tool to do it, or is there a way around it (C-clamp/hammer etc.) that doesn't require a special tool?
I had the same problem when installing springs....oops! cut the boot!
The tool is $99 to rent, but of course you get your money back when its returned.
It's a ball joint press kit..will come with a clamp and several cups and things. I actually made my own to pop the ball joint out, but had to rent the real kit to reinstall it.
^^^ They sell a full kit on ebay for $53, both upper, both lower, and inner and outer tie rods.
http://cgi.ebay.com/ebaymotors/ws/eB...m=360054166002
The Moog ones from napa are good too but kinda pricey.
http://www.napaonline.com/MasterPage...Susp&VehCode=Y
Cool ****. Thanks alot. I'll have to do that.
I didn't have any luck with the ball joint removal/installer tool, the one that looks like a big c-clamp with all the different "cup" adapters. I ended up using a hydraulic press to push the old ones out and the new ones in.
I got AFCO lower Ball Joints from summit for $30 pair (although they say Moog Problem solver on them)
I will go rent the tool..
I still have one question though:
They look like this:
What the heck is the little brass thing for? (obviously there's the dust boot, nut and cotter pin and the ball joint itself..)
No I wasn't kidding--I probably would have figured it out after I took them out of the package, but it looks like they were pre-greased so I didn't want to get messy and I was hard to see where it would have gone.
Zerk fitting...learn something new everyday...
Be careful installing that zerk fitting. You DO NOT need to "lean" on them. You will twist it off if you start trying to torque it in there with a bunch of force. Just use a 1/4" drive ratchet and wind it in until it bottoms and a very slight bit past that (just slightly snug). They break rather easily if you get too heavy handed with it.
GOOD ADVICE!
The Afco's work as advertised with lower friction and I'm glad I found them.
Vernon
Say John, I got AFCO lower ball-joints from Smiley's Racing and they don't look like that, the Afco's are a work of art and are silver cadium plated or similiar. Also, I think Summit screwed up and sent you Moog's.
Vernon
Vernon
I understand what you're saying Foxxtron and it wouldn't surprise me if Moog was producing them for Afco. But I can say that I install plenty of Moog's and other premium stock replacement types and I've never seen or felt a ball joint like the Afco Low Friction. I'm pretty sure they are differerent. At least the ones I put in my car were. I was impressed with them.
Another thing that's common in the auto parts industry is for people to return the boxes with a different or old part inside to get their money back or because they changed their mind and couldn't return the others etc.
If it were my car, money, and time I would get on the phone with Afco and verify that their LF ball-joints may also be labeled as Moog Problem Solvers before I put them in. Mine were not.
Vernon
Vernon
Yes, they're different and look different as well, but they both are likely to be manufactured by them since I too have the 20039LF installed and they didn't say it either, but by taking some older 20039LF's apart, the parts had similar marking features on them.
I'm not readily familiar with AFCO's resale policy, but according to the AFCO website, the price for LF's are 46.75 USD, which is also what I was charged by AFCO since Summit didn't seem to have them in stock at the time. johnh seemed to have paid 30 USD for them, which is the usual price. So far it appears he got what he ordered.
Just had to include the information for clarity purposes.
AFC-20039 BALL JOINT A Shipped on 05/29/08 $15.25 2 $30.50
The packaging, sealed plastic bag said AFCO, the Ball joint bottom had Moog Problem Solver on them. I read on here, that the Moog PS were a decent parts so I installed them. There I guess aren't the LF variety.
I got them in, it took a little longer than 5 minutes though...the old ones were stubborn to pop off and the press kit I had took a bit of testing to get the right combination of tubes and such to press them out and new ones in.
Yes I was very gentle with the Zerk fittings, just got them in and snug with the 1/4" ratchet.
In true fashion, now there's a slight noise coming from the left front wheel sounds like a warped brake rotor to me--goes away with the brakes on. Probably since the lower BJ, upper BJ, endlinks, shocks/springs all had some 90K miles on them there probably allowed too much play on the front wheels...I had the suspicion that the rotors had some pulsing on stopping at times...oh well brakes are pretty easy.
Edit: and oh yeah: Thanks for your help guys.
