STRANGE front shock, do you run the shield/jounce bumper????
If you're using the factory upper a-arm you can mount a bumpstop up above the balljoint; first, just pop the upper balljoint out of the spindle then swing the a-arm up until you can see where you need to drill a hole to mount your poly. bumpstop, I think there's a small hole already there, not 100% sure.
