qa1's i got some from my roller it has one knob on it which was do i adjust it for the track? |
english please. im assuming you mean which way...well..are these fronts or rears? SA or DA? |
sorry i dont know much about these they are the front coil overs and have only one adjustible knob whats sa or da? |
Hello, sa is single adjustable, da is double adjustable. You have the single adjustable shocks. Turning the knob clockwise will stiffen up the shocks,counter clockwise softens them up. You will need to test it at the track because each car is different. Try 1-2 clicks clockwise (harder) for a starting point. You will need to adjust it to what works best for your car. If you have any questions please give us a call. Our tech/sales dept is open Mon-Fri 8:30AM-6:00PM. We will be closed this friday for the holiday. |
single adjustable or double adjustable. if they have one knob then they are sa's. the bump (compression) is fixed and the rebound is adjustable. set them to full soft (-) for the track so the frontend can rise and if these are the r-series they should hold the nose up for quite a while before it settles back down. the f series are the street shock and will act the same but it has different valving. |
edit...im assuming drag racing... |
thanks yea its for the track this weekend i just got these last week on a roller i bought along with a strange 9in setup thanks again for the help 99ssleeper was i tolerable? :chug: |
Originally Posted by 89Formulaws6
(Post 9666229)
99ssleeper was i tolerable? :chug: :secret2: |
Good luck!!:D |
| All times are GMT -5. The time now is 02:21 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
