Front Sway bar Bushings and Brackets
I'm looking for replacements Front Sway bar Bushings and also the Brackets for my 2001 Camaro SS. Any one know what part numbers and also a place I can buy these.
LS1TECH Sponsor
I have them.....
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
LS1TECH Sponsor
D-bushings and brackets are $20. Endlinks are also about $20. There is a rear kit that's about $35 that has both the mount bushings, brackets and links as well.
__________________
LS1TECH Sponsor
I don't have them on my website, so it's best to call. You can do the springs at the same time.
__________________
LS1TECH Sponsor
Then leave me a message. 4 incoming lines, one set of ears.
__________________
Thanks Sam. I received the bushings and end links. I have a question on the instructions on the enk links It states to have the car at ride height when installing. I was going to drive my car up on ramps, So would I have to bring up the rear using jacks stands to make it even with the front or can I leave the rear on the groud with just the front end up?
