wheel bearing questions
I am getting a howl from the right front and am convinced its the wheel bearing. Is this a part I should replace in pairs? The car has 55K miles on it. Am I better off doing both of them, or can I save some $$$ and just do the right side?
Just replace them as they fail. They're not exactly "cheap", and sometimes you get lucky and get one that lasts forever, and sometimes you get one that fails within a week .
I'm 90% sure its the wheel bearing...the tires have less than 1000 miles on them, the sound started suddenly and varies with speed, but doesn't change when going around corners or braking.
Jack the front of the car up and, with the wheel on, check for slack in the bearing by grabbing the top and bottom of the tire and shaking it...
Replace them as they go, our cars front wheel bearings come as a hub, bearing, ABS sensor assembly and they aren't cheap. They are, however, easy to replace.
it is possible to get sound coming from brakes, also, so be sure to double-check to make sure a rock or some other foreign object hasn't made its way in between the pad & the rotor....should be easy to tell, as it will generally leave gouges or markings on the rotor, but it may be a good idea to inspect the pads, anyway, especially if it's been a while since they were replaced.
otherwise, it's likely the bearing, so just replace as needed.
