LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   Suspension & Brakes (https://ls1tech.com/forums/suspension-brakes-16/)
-   -   boxed sfc's make a huge difference? (https://ls1tech.com/forums/suspension-brakes/997153-boxed-sfcs-make-huge-difference.html)
SLP Firehawk Oct 5, 2008 03:40 PM
i am getting sfc's boxed style from eric and midwest chassis and wanted to know if anyone that installed sfc's on their car made a huge difference and with what handeling or launching at the strip?
WS6addiction Oct 6, 2008 07:55 AM
I did my suspension mods all at once so I can't say how much the sfc's contributed, but the difference was very noticable. Body flex is completely gone. Judging from your #'s, your gonna feel a big difference.
SLP Firehawk Oct 6, 2008 08:04 AM
that sounds great i plan on getting a chomoly adjustable panhard bar also should help out alot with launching with the new 9" at the track
UMI Performance Oct 6, 2008 08:48 AM
Hello,
Whether the SFC's are boxed or tubular it won't make a difference as long as the items are constructed and designed correctly.
Please keep us in mind as well, we offer a variety of options starting at $155 a set, powder coated red or black and with 100% bolt in options.
http://www.umiperformance.com/produc...ategory_id=129
If you have any questions please ask. Thank you!
Ryan
Frans96SS Oct 6, 2008 08:49 AM
They are deff worth doing. Let me know if you need help with the install.
z28bryan Oct 6, 2008 09:18 AM
My favorite thing about mine is using them as a jack point and lifting the whole entire side of the car up.
For drag racing, they would be a good insurance policy. Cars that hook and make big power I guess can twist and I don't think that makes it any easier going straight. Whether you make enough power and traction to do that or if you will do it in the future is maybe a question you'd want to ask yourself. Either way it can't hurt, unless you want to autox in fstock or STU. Some people report more noise transmitting through, other's dont.
Big Bird WS6 Oct 6, 2008 10:29 AM
Originally Posted by UMI Performance (Post 10235176)
Hello,
Ryan
i have Ryan's(UMI) three point. and hell i could feel a difference. they are great. thatnks for the good stuff ryan
UMI Performance Oct 6, 2008 10:31 AM
I didn't even know you had them.. thanks for the kind words and I am glad you like them :D
BMR Tech2 Oct 6, 2008 10:38 AM
Sub frame connectors no matter if they are boxed or tubular are always a good choice no matter what kind of driving you do. We feel that the boxed version are a stronger product than the tubular because of the torsional twisting that can occur with the tubular connectors. All of our connectors are of the weld in version.
Frans96SS Oct 6, 2008 11:11 AM
Originally Posted by BMR Sales (Post 10235731)
Sub frame connectors no matter if they are boxed or tubular are always a good choice no matter what kind of driving you do. We feel that the boxed version are a stronger product than the tubular because of the torsional twisting that can occur with the tubular connectors. Al of our conmnectors are of the weld in version.
I agree. I used BMR boxed on all cars i put them on.
Big Bird WS6 Oct 6, 2008 03:02 PM
yep and bad ass. makes it fell like solid car. not a car with two polls on the out side(since i have three pint)
SLP Firehawk Oct 6, 2008 05:07 PM
i heard 3 pt can interfer with exhaust and possibly my torque arm. the main reason i am putting them in is because i am putting in my 9" and i figured why not just do it all at the same time... i was thinking about a chromoly panhard bar too
Big Bird WS6 Oct 6, 2008 10:07 PM
mine stop befor they get into the tunnel. no messing with my exhust or torgue arm. does beeter with tunnel mount torque arm
UMI Performance Oct 7, 2008 08:27 AM
The 3-Point SFC's will not interfere with your exhaust or the torque arm. Unless you have an aftermarket torque arm that welds into the SFC's you will be just fine.
Hope that helps!
Ryan
SLP Firehawk Oct 7, 2008 09:10 AM
are the 3 point alot stronger? because i was told the boxed 2 pt are pretty good 2
UMI Performance Oct 7, 2008 09:15 AM
The 2-Point style SFC's will work very well for every application. We recommend the 3-Point SFC's when the vehicle is being aggressively raced or when running a short style tunnel mounted torque arm.
Both the 2-Point tubular or boxed will work great for every application.
If I can help anymore please ask. Thank you!
Ryan
Alex212 Oct 7, 2008 11:03 AM
I'm also thinking about adding a set of these, but not sure which way to go. Here's my situation...01 Z28 with 33k mi. Bone stock suspension except for upgraded LCA bushings from the waffle type to the solid 1LE type, which helped.
I just want to improve the ride and handling without re-doing the whole suspension. The car is not raced it's just my weekend cruiser. Should I go with 2 pt or 3 pt? Also I want to use bolt-in type SFC. Thanks for your feedback.
UMI Performance Oct 7, 2008 11:56 AM
I would recommend the 2-Point bolt in set-up for your application... they are 100% bolt in which means no holes to drill and no cutting and they can be removed at any time and no one would ever know they were ever there. For handling the SFC's might not make a noticeable difference but they add protection to the chassis.
Here are the SFC's I would recommend- www.umiperformance.com/2002
Ryan
jmilz28 Oct 7, 2008 01:45 PM
Big difference, no. Noticeable, yes. Shocks alone (such as Konis from UMI or Strano) are what you need first. My humble Bilsteins made as much improvement as the rest of my chassis/sups. mods COMBINED. I wouldn't buy the hard chassis parts from anyone except UMI and suspension from anyone but Sam.
SimRacer1 Oct 7, 2008 10:45 PM
So subframe connectors hurt you when it comes to autox/roadracing (racing on an actual race track)? I thought that SFCs stiffening the chassis would improve handling as well???... Am i missing something here?
© 2026 MH Sub I, LLC dba Internet Brands
