416 stroker LS3 PRC 255s Longblock Houston
416 Stroker LS3 PRC 255s Longblock
Made 548rwhp on break in tune with low timing in El Paso 6kft DA
Engine has around 500 miles on it and is ready to drop in and run held 40psi oil pressure hot idle.
Block was zero decked to square it up and line honed for the ARP main stud kit by Car Parts Machine in EPT
Crank was also balanced to rotating assy and bearings
Everything was bought brand new have a few of the boxes still
Started out with a NEW LS3 GM aluminum block
LS3 valley cover
Lunati Voodoo 4 inch forged crankshaft 24x
Lunati Voodoo 6.125" forged h beam rods ARP 2000 bolts
Weisco 4.165" flat tops forged pistons
King Tri-metal bearings
PRC 255 LS3 heads stainless valves .660 dual springs titanium retainers milled .035
GM LS3 rockers with Comp Cams Trunion upgrade
12:1 compression
Comp Cams chromoly pushrods
Melling high volume oil pump
Cometic mls head gaskets
ARP main stud kit
ARP head stud kit
Texas Speed 244/248 .615"/.615" 3 bolt stroker cam for ls3 style heads
LS7 lifters
ls2 front cover with 1 x cam gear
F body oil pan and pick up tube
Engine is in the car but I can pull it in 1.5 hrs if someone wants it.
going a different route with car
have the ls3 intake setup for more if you need that
would cost over $10k to reproduce this setup
$6500 cash come get it or I can ship if you pay
would like to sell together but would consider $2000-heads $5000 shortblock with the covers oilpump and pan
may trade for ls powered cars or trucks or lightning or other cool vehicles
I like LS parts also
979267020one
LS3 valley cover
12:1 compression
ARP main stud kit
ARP head stud kit
LS7 lifters
979267020one
