LS6 intake on Silverado Has anyone successfully installed an LS6 intake on a 5.3L Silverado? I have an 02 Sierra with a 5.3L and I wanted to install an LS6 intake and fuel rails etc. As far as the fan being in the way I will be installing electric fans from an 07 Silverado, I will also be installing a p&p tb and a cold air intake. Just wanted to see if anyone had some pics or info to help me out. Thanks. Aslo I will be doing a cam swap, headers, msd coils, msd wires, true duals etc. Just bolt on stuff. Please help me out if you have some info. |
i have 28.8 injectors/water pump/fuel rails for sale all of which you need for the swap, bc i was going to do it, then needed some cash so I sold the intake but stil have the rest of this |
yes there are several on pt.net that have done it as well as myself. Search is your friend upper right corner, good luck. |
Originally Posted by v8
(Post 11609256)
http://www.performancetrucks.net/for...ghlight=wieand http://www.performancetrucks.net/for...ghlight=wieand V8 and I swapped it out in a day.. :D |
thats right daniel, my second time was alot easier ahhhahaaa |
keep the truck intake, you wont benefit nothing from an LS6 intake, ask v8... also stock coil packs are as good as MSD's... |
spend your money on better things. |
Originally Posted by ap2002
(Post 11615166)
Originally Posted by sleepersilverado
(Post 11615732)
spend your money on better things. Does anyone agree on the looks part? |
your alternator is going to sit 5" higher then the intake, best thing to do is get the camaro setup for all pulleys and brackets, for the best look. |
(Post 11619990)
shim the vette alternator bracket....or the whole vette accessories :-) |
© 2024 MH Sub I, LLC dba Internet Brands
