Need help with window track in the T.a Well the track is broken. When you roll the window up the glass falls in.And the glass can slide around in the door. Anybuddy had this problem and fixed it.IF so give me some info also i would glady take it to a shop.Does anyone happen to know a shop that can handle this? I wana get the windows retinted.But cant intill get this done.Thanks in advance |
Any help would be greatly appreciated..:nod:Thanks! |
afternoon bump:P |
I guess not. Someone help please. |
Have you taken the door panel off to see what exactly is broken? |
Originally Posted by Super-Bat
(Post 12156271)
Take the door panel off. The window run channel (looks like weather stripping) that guides it down could be bad, the actual window where it bolts down to the window regulator (the scissor arms) could be broken, or the regulator itself could be bad. |
Originally Posted by 5w20
(Post 12156638)
© 2024 MH Sub I, LLC dba Internet Brands
