would u change u wheel studs i bought a complete set of arp wheels studs for a steal and i was just wondering is it really worth changing .... i have prostars on my car and i been workin on my car and im just looking at them wondering if i should put them on |
you have them and it wouldnt hurt, why not? |
Yes I would. |
you running DR's on a 10-bolt, right? i think you'll break the rear before the studs. |
i got them and just put them n my car.... i havent even attempted to put them on.... i paid 20 bucks for all 20 so i thought it was pretty good.... but i also got a deal when i bought my prostars thats y they were so cheap but what do i benefit for them? |
i believe you need them with openended lug nuts for bracket racing. they are also suppose to be stronger than the stock studs so you wont break them, however i have 13k miles daily driving on my stock studs with the long lug nuts |
yes im running a 325 50 15 nitto |
a few of my threads got messed up, i'll give you the $20 for them if you decide you dont need em |
I had them put on my car, I think it was a good mod. I had broke one of the stock ones while torquing the wheels back on. |
5:2 WHEELS Hubcaps must be removed for inspectors, who will check for loose lugs, cracked wheels, worn or oversize lug holes, and condition of spindles, axle nuts, cotter pins, etc. Snap-on hubcaps are prohibited on any class car. The use of “spinner” style wheels or any wheel design that incorporates movable pieces while vehicle is in motion or stationary are prohibited. Each car in competition must be equipped with automotive-type wheels with a minimum 12 inches of diameter unless Class Requirements stipulate otherwise. Motorcycle wheels or lightweight automotive wire wheels must be equipped with .100-inch minimum diameter steel spokes, properly cross-laced to provide maximum strength. All spoke holes in rim and hub must be laced. Omissions to lighten wheels prohibited. The thread engagement on all wheel studs to the lug nut, or lug bolts to wheel hubs, must be equivalent to or greater than the diameter of the stud/bolt. Length of the stud/bolt does not determine permissibility. (Example: A 7/16-inch stud must be thoroughly engaged through the threads in the hex portion of the lug a minimum of 7/16-inch.) Wheel spacer permitted. Spacer to be either hub-centric or lug-centric and must fit with minimal clearance to retain concentricity. The wheel spacer must not reduce the minimum permitted thread engagement below the limits established by fastener diameter. (See example as stated above.) No stacking of wheel spacers allowed. Maximum rim width on any car: 16 inches. No rear wheel discs or Diameter of stud At least diameter of stud Washer Lug nut |
Ask Dirty about wheel studs. |
Just do it and be done with it. Seen too many stock studs break before a 10 bolt does. Especially on a m6 car. Where's JP to insert the Mellow Yellow "FAIL" pic. haha |
i heard mellows story but not jps |
Originally Posted by BadCompany VP WS6
(Post 12678623)
Just do it and be done with it. Seen too many stock studs break before a 10 bolt does. Especially on a m6 car. Where's JP to insert the Mellow Yellow "FAIL" pic. haha yes you need wheel studs!! Mellowyellow.... http://i34.photobucket.com/albums/d1...7/mellow-1.jpg |
Originally Posted by Elite_Hot_Rod
(Post 12678535)
I sent those studs with those wheels for a reason bro! LOL Put them on and feel safer that you are doing it the right way and not half-assing it. |
Originally Posted by BlackLT1Z
(Post 12679228)
half-assing it. |
ill show u half ass when im dragn u half ass on the pedal |
Originally Posted by txh0tb0i972
(Post 12679513)
(Post 12678623)
Just do it and be done with it. Seen too many stock studs break before a 10 bolt does. Especially on a m6 car. Where's JP to insert the Mellow Yellow "FAIL" pic. haha this has good wheel studs and rear haha |
© 2024 MH Sub I, LLC dba Internet Brands
