Gear install help
I found some very thorough instructions the net with great pictures. Followed the directions to a T and kept adjusting the shims till the backlash was within spec and the wipe pattern was right on. I put 50k miles on that set of gears, running 37" tires, pulled trailers and generally abused the truck every way I could. Never had an issue with gear noise or breakage. I did break an axle, but the R&P was fine.
I guess my opinion is, it may take you a lot longer than a pro to install the gears, but as long as you keep adjusting it till the wipe pattern is correct and the backlash is within spec you can do just as good of a job.
You are correct. That is the correct way. Not always the war it happens in a driveway... Trust me ive seen it all!
