What's the biggest HP drain in a cam'd car?
#42
Hahaha no guys I am not spraying! My car is stock and I have had more than one person tear my car apart looking for a kit. Alex there is something wrong with your car cause I was waiting for you to come around me like I was sitting still. You need to stop by Sqr and let them take a look at it.....that's 2 of your cars I took down now lol
#43
Joe go find another stock car that is similar to his and if its the same out come his car didn't beat you because its a freak...it beat you because yours is a slouch...easiest way to find out...or hit the dyno and compare current numbers to the numbers immediately after the install
#44
115k miles is a lot, especially when most of those miles were backed with an MS3.
There's really nothing "wrong" with your car but set aside some cash and spend some money on your babe. Fix all the little issues, have it buffed/waxed, freshen up the motor and re-tune it. Nothing like a fresh car
Finally fixed my headlight motor, window motor, gave it a good bad and shampoo'd it and fell in love with my car again.
#45
Michael, what gear did you punch it in? 2nd or 3rd?
Idk what's wrong with my car. I'm gonna get it on a dyno I guess...
I swapped out my gf's IAT sensor with mine since I have her's bypassed.
I am gonna go to my exhaust guy soon and see if that "weep hole" is supoosed to be there on my Y pipe.
I'm gonna check plugs this weekend. Maybe I'll do a tune up and give myself an excuse to buy Hotwirez. Plus I can get any NGK plugs for $5 a piece...
And I'm gonna attempt to port and polish my TB on Sat...
What coils is it that everyone likes to put on their cars? They're off a stock truck, but have more power...
#49
#50
TR55- $1.99 each. Get a new fuel filter. New wires $60.00 8.5 MSD Super conductors. Get a re-tune. Clean out your air filter. Sea-foam it. Change the oil. All this should put you back where it should be. And don't waste your money on coil packs. If it is still a turd, then it is something else. And if you are gonna attempt to do you TB yourself make sure you know what your doing or it will end up looking like you took a chain saw to it.....honestly I would just buy a Shaner One.
BTW, NAPA has the TR55 for $1.89
#52
I would start out with the cheap stuff first though. Get new plugs and msd wires, what heat range plug are you running? If you're heads/cam get some TR6s, I left mine gapped to .35 and it runs and idles great, even on cold startup.
If that don't fix the issue, look at all your emissions/exhaust to see if there could be anything wrong; exhaust leaks, bad o2s, etc...
Are you speed density, or MAF tuned? The altitude changes could be affecting your tune...
If all else fails, get it re-tuned man... if that doesn't fix it, swap valvesprings, if that doesn't fix it... well then idk.
#54
Wow I did not catch that.....yes he should deff change out those valve springs. I am surprised he has not broke one yet.
#56
Yeah I used to work WITH Chase Hatcher. Back in the day he was just a regular ole mechanic. Not some fancy manager.
I'm gonna play with the car tomorrow. I need to figure this **** out. It's bugging the hell out of me. I thought some of the NGKs were more expensive than that... Nevermind. Or maybe I was looking at Bosch's super quattro plutonium-iradium infused gold plated magic plugs...
Random question.... Does anyone know where I can get a Poly trans mount for a V6 f-body? I tried to put one on my gf's firebird and the generic one from Autozone didn't fit...
#57
I did plugs and wires today and wen't for a drive. It seems to have a little more power now. I can spin the tires easier now.
I found that cylendar 8 (pass rear) plug had not been changed in a while... 3 of the plugs broke while breaking the threads loose. And some of the wires were just old and came apart while removing the wire.
I'm pretty sure that cylendar 8 plug was left in there because of the difficulty of replacing it.
Here's an average plug I took out beside the pass rear tire...
#59
Dont go out and find a race and get drug because then they will just say that its an excuse...that's why I never raced unless my **** was running right...I've ran across those kind of people many of times
#60
Every race has an excuse. The bottom line is that the car isn't faster or the driver isn't better.
I never got to race that guy. He wouldn't ever answer me on FB. Then on Thursday, I saw him at the bar and he said he didn't wanna race cause he was trying to sell his car lol. I even tried to get him to do it for ***** and giggles, but he didn't wanna commit to anything.
