Best 02 Sensors?
going to have my pacesetters and tsp off road installed this weekend. I was wondering whats the best brand of 02's that you all have used so i can delete the rears??? thanks putos!
![The Pimp](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_pimp.gif)
Denso or bosch. Not really sure why you're buying new ones if the old ones work. For the part they are, they're not cheap. Just replace them when one breaks. You can get extensions for 15 bucks and use the stock ones.
Concerning the Delete your going to have to either get MIL eliminators, a programmer, or have a tuner edit them out. Has nothing to do with what 02's you run.
LS1Tech Premium Sponsor
We only use Delco! We used to use some Denso and Bosch, but had far too many defective brand new out of the box.
Remember, O2 sensors are a maintenance item, and should not only be replaced when they go bad! Their average life is 50-75K miles, and they can cost you fuel mileage well before the DTC light comes on!
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic110569_2.gif)
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
wow its a toss up still between the ac delco and the bosch/denso users. Thanks guys for the answers..
I have another question though. Can 02 sensors be connected if you are straight piped?
If you are asking if you can keep them connected and just strapped to the undercarriage to prevent DTC's -that won't work; they have to live in the exhaust stream. I've never considered if you could mount them downstream in the pipe to prevent requiring their deletion by a tune. That might work but you will likely still get DTC's. Their purpose is to monitor cat efficiency.
