98 Trans Am Steering very heavy and repulsive??
Old 08-08-2012, 04:55 AM
Sheikh Waqil's Avatar
Default 98 Trans Am Steering very heavy and repulsive??
Ok guys I know dat f bodies have stiff steering but my 98 Trans Am surely has a problem. When I bought the car the steering was very heavy, and the thing is sometimes the steering was heavier and sometimes lighter. So I decided to replace the PS pump and since then it does the same thing. Also after replacing the pump when I turn my steering wheel it makes a whining noise, I thought that it would go away after a week but it still has been doing it for like 3 months now. And sometimes when I am turning esp when I turn all the way it is so hard to turn. The steering feels as if its repulsing against me,no joke!!!! Suppose if I am in a tight space and I have put the car on reverse and turn then turn all the way, the steering feels very repulsive !!!!!
My friend told me that I need a new rack and pinion as its probably making the PS pump work too hard. But I am not aware of any leaks from the rack and pinion so I am confused here. BTW I got the replacement pump from O Reillys and its remanufactured.
So does anyone know what's going on with my power steering???!! Do I need to replace the rack even thought its not leaking? What else can make my steering wheel behave like this???
Old 08-12-2012, 11:42 AM
ageorge7's Avatar
Im not sure what the deal is here but my car did the same thing after i replaced my pump. I replaced it again and that went away. It still whines every now and then but it doesn't try to fight me. I would say try another pump but i am no expert.
Edit: also make sure it properly bled
The following users liked this post:
Lukeypooky (11-08-2020)
Old 08-12-2012, 12:02 PM
souljaboy9768's Avatar
Try jacking the front end up while bleeding, it helped me
Old 08-12-2012, 10:48 PM
chrysler kid's Avatar
Unfortunately gm skimped on the rack and pinion in these cars. Try bleedIng the system your new pump should not be whining, but to get a good feel in the wheel you will need a new rack and pinion
Quick Reply: 98 Trans Am Steering very heavy and repulsive??
