what oil are you guys using?
I have started using joe gibbs ls30 since the cam swap for multiple reasons here is a little info on it and if you want to try it out send me a pm and I can tell you where to get it for the lowest price. If you are a local hpd member and you order it, I will personally deliver it to you! Shipping can be arranged for anyone outside of Houston.High Zinc Content - Higher level of Zinc (ZDP) delivers proper anti-wear protection for high output engines and aggressive cam designsExtra Film Thickness - Advanced synthetic technology provides high shear protection for supercharged enginesStorage Protection - Protects against rust and corrosion damage when your engine is not running. Defends against moisture drawn into the engine by modern ethanol blended fuels
