well got the bird back together but small problem
ok so got the 6.0 in my bird today got everything hooked up but wont start.
any assistance what i should look for in case i missed things
also no fuel coming out of headers so i assume injectors arnt opening how should i test for this other than noid tester.
No fuel out of the headers? Why would there be fuel in the headers?
I'm going out on a limb and saying ur getting air and spark, but no fuel?
What all did you switch out? Short block only or block, heads, intake, fuel system, tune ect.
i checked rail and fuel pours out schrader valve, thank you for the suggestion though
i appreciate any input my meds make my memory **** so im sure i forgot something or just not thinking of something, so thank you to anyone offering input kind of using it like a list to go hmm yup did that just waiting for that one thing to be like "damn nope didn't do that". thats how i remembered i forgotten to tighten rod bolts before start up, blah stupid meds
ok so got spark and fuel now but still not starting
could the 7 month old gas be effecting it ?? I know i read somewhere that old fuel sux but could it have gone that bad that fast
Does your gas smell like varnish or gasoline? Had trouble starting mine and had to evacuate the whole tank. Fresh gas and a bottle of red stabil fired right up.
Also check your camshaft position sensor (back of the block near oil pressure sensor). Accidentally switched the camshaft position sensor and MAP sensors on mine. That was hell tracing with blank replacement connectors and matching wires.
how would i check the vats?? security lights not on and its the original pcm and bcm for the car or well one ive been using for almost 4 yrs since the original v8 swap
Modern gasoline has a crazy short shelf life. Heard its like 30 days from the pump. Something about the ethanol separating.
Drain your tank completely, dump a bottle of the red sta-bil in the tank, then at least 5 Gal of gas behind it. Red sta-bil can be found at any parts store.
