5th gen newbie here Ok on the new 5th gens how do you turn on the foglamps and also how do you set the cruise? |
Press the foglamps button. Press the cruise control button. |
Originally Posted by Lazzarus
(Post 17668346)
on the cruise push the button the little indicator lights up then hit set when you get to the speed you want... the fogs push in on the headlight switch that should turn them on |
5th gen camaros don't have fogs just daytime running lamps that look like fogs in the bumper |
5th Gen Problems :jest: |
No fog lights. Those are day time lamps. Wack.iknow. gotta do some custom work for fogs man. Fun and easy |
welcome |
I believe aac or oracle sells a patch harness kit with the non rs headlight switch so that the fogs can be turned on at anytime. best thing to do with those is get the led lamps the have for those so they match the hid lamps. oh yea get them rear taillight rings body colored. the chrome makes them look bad. |
Read your owners manual it will show ya. |
If all else fails, start turning and pressing all buttons/switches. |
5th Gens don't have fog lamps only DayTimeLamps As for the cruise control look on the left side of the wheel. The last button on the right flip it up and press the stroll button down and BINGO http://cdn.dealerfire.com/stock/VACH...3/image-10.jpg |
© 2024 MH Sub I, LLC dba Internet Brands
