Need advice on 2002 ranger
Ok for about a week now I've been having some issues with truck starting. Plenty of power but not firing. Last time I had this issue ended up being the inertia switch. After being replaced boom good to go for about 6 months.
Now, Same thing, tried resetting inertia switch, nothing
Check the fuel pressure 65 psi boom starts right up.
Sitting about 3 days again same thing. Inertia switch is good but this time when cranking, it sounds like its skipping a beat. Just replaced camshaft position sensor, nothing. Go to check fuel pressure and after hooking up gauge, key on, 65 psi and cranks right up.
I just replaced the cam synchro shaft. Started up. Turned off no sound from fuel pump at all. Ive got power at the inertia switch plug in and at fuel pump connector. Is all that's left the fuel pump? Relays check out good and all.
Edit:
Nevermind, the ranger doesn't use one. The 04-08 F150 does, but not that one.
