brick masons?
Right now I can't even get someone to come out and give me a price. I keep hearing how busy everyone is. ??? I worked on a mason crew during the summers in college and feel comfortable laying brick so I may end up having to do it myself but was curious what the cost should be and whether or not it would be just easier to pay someone.
Thanks.
Anyway, I would check on getting the brick you need first. Call the supplier if you know who it was and give them your address. Make sure you can get the brick. If its Acme, they keep the files for 20 years.
As for the price. I would charge about 1000.00 at least not including the brick pretty easily depending on what it needs and if I have to haul off the debris. You'll be lucky if you find the brick in stock anywhere. Most likely have to order it and it can take up to 3 months to get it if it has to be made. You go into their next production run of that color. And you will buy a full cube since they most likely will not sell just what you need.
Good luck.
Good luck.
Thank you again.
Scott
