Summit 6.0 engine blows
Should've just had one picked up at the local junkyard and fed it 25lbs of boost on "stock untouched internals" and ran 7's. The internet told me you could that kind of stuff without batting an eye.
Well what I'd like to know is if it's a known issue is ATK contacting customers who purchased the 6.0 ? I'm looking to buy a suburban with an ATK notor just installed with only 5 thousand miles. I'm a new member and joined to research the ATK rebuild. So if I buy the Suburban can I expect the motor to come apart in 20 thousand miles? That would totally negate a good deal on this Suburban
OP def flipped out because they didn't just give him a brand new motor immediately. Sounds like they are being very reasonable and taking care of you. You need to settle down. And if you're 48 why in the hell is ATK talking to your mom for you? And if you're so behind on work than why are you spending all of the time to drive the motor there and back?
Mommy, my motow went boom boom and they wont gimme anothew one, wwwaaahhh!
Motor blows up. Still under warranty. Gets motor warrantied. Cries and tells everyone how fucked up the company that is helping his. GTFO dude.
Just seems to me if you know you have a problem with the keepers you can contact your customers to have him replace the keepers which is cheaper than having a full motor rebuild. I only put about 4000 miles a year on my vehicle it's that I Would-be long out of warranty by the time the motor went South .
If ATK offered an extended warranty for X amount of dollars for say 5 years with a limit on the miles that Would-be awesome .And it would probably alleviate My concerns .But I don't think they do that and I doubt Anyone else does. So I don't have any misconceptions about that.
We’ve identified a problem with some keepers from one of our suppliers that altered the spring height enough to cause premature spring failure (25k miles in your case), if the engine is operated in enough cycles at high RPM. These are Howards valve springs and a very high quality spring.
SOME KEEPERS, ONE SUPPLIER, IF OPERATED IN ENOUGH CYCLES AT HIGH RPM.
They aren't going to go chasing this.
Yeah I get that, but if there was a way to identify the keepers that's a much easier fix I could do myself vs motor going south and having to pay a mechanic to remove and reinstall the new motor and deal with that costly mess.
#32
Atk
I did not flip out and just expect a new engine. I had another employee(son) handle this. When Summit was notified they just kinda blew him off. When ATK was contacted, they stated they would pick the motor up and inspect the damage. We delivered the engine to them, at their shop. My thinking of this was that the sooner they got the motor, the faster I could have my truck up and running. Hell, I could see the damage. This motor was never abused and was taken care of. This motor belonged in a work truck. I thought I bought a crate motor for reliability and just posted word for word what my experience was, at no point did I lie or call anybody names. I did not cry about it. I WROTE ABOUT MY EXPERIENCE WITH BOTH SUMMIT AND ATK. I do not post a ton of stuff on this site or any other. But I read this site almost everyday. ATK replaced the engine and Summit gave a discount on parts to replace the engine. I should have updated this thread. In the end, everything worked out. NO, I was not happy about the time it took to get this handled. I do not expect for the world to stop turning and fix my problems, but I am also a realistic person.
