Advice for Engine Reduced Power
I have a 2005 single cab turbo truck that keeps going into reduced engine power. I need someone to fix my truck! I’ve swapped TB taken to multiple shops. Where the shop is doesn’t really matter to me. DFW, San Antonio, Houston, Austin. Would like it fixed, retuned, dynoed.
Does the engine make a "pop" sound out the exhaust before it goes into reduced power?
There is an airflow table in diagnostic section that needs to be adjust for turbo applications. The table prevents a "run away" DBW throttle, if it sees higher airflow than expected it goes into limp mode (throttle barely does anything). Mine was doing this, and the exhaust would make a backfire right before it went into limp mode
Def need it scanned before anyone on here can help.
Did you upgrade the transmission to an 80E? or is this truck completely stock except for adding a turbo system
Did you happen to glance at the coolant temp? These engines will shut off if they overheat and go into REP mode once started back up again
I had this happen this week to me. I swapped the TBSS on a 6.0 truck motor. It looks like it is the first gen used X-link i have. I reset the computer and all is well. Seems to be a common issue with the x-link when it is hot and humid. Like it is all the time here. Try resetting the computer and see what happens.
