went to track. help
Old Mar 5, 2005 | 03:14 PM
stevensLS1's Avatar
Default went to track. help
ok the first time i went i ran a 13.2 that was on some khumo 712s. i went to the track last night and ran a best of 12.7 and 1.9 60 fts. second time was with nitto drag radials. both runs were with mods in sig. i stalled up this time to like 1700 or so am i doing something wrong??? thx guys.
Old Mar 5, 2005 | 03:21 PM
BBADWS6's Avatar
Is your suspension completely stock? Ive heard of people cutting 1.7 sixty foots on good year eagle ones. How much did you heat up your nittos? I think you should definatly be a faster than that, but it takes time in the seat to figure out how the car likes to be driven.
Old Mar 5, 2005 | 03:26 PM
Saad06's Avatar
uhh.. stalling to 1700 on a 2800 stall?... stall HIGHER... on warmed up DR's and u should hit better 60's ... but 12.7 is a solid time..
Old Mar 5, 2005 | 03:51 PM
2 SLOW's Avatar
It doesn't seem like much thought was put into your mods. What brand is your stall? If its a Vig don't stall it up that high, they 60 better if you let it flash from 1000rpm. If its a Yank, you should stall it up higher. Whats your trap speed? Were you spinning?
Old Mar 5, 2005 | 04:35 PM
Modsquad's Avatar
10-Second Club
My Vig does better stalled up than flashed....I have a Vig 3200. As for your times, I was running 12.5's with a similar setup on street rims with drag radials. I now have ET Streets as well as 3.42's instead of 2.73 gears & run 11.9x's-12.ohz. My 60's are 1.6x on motor...I think I've gotten some high 1.5xs too. I get hight 1.4x's & low 1.5's on a 75 shot
Old Mar 6, 2005 | 12:45 AM
stevensLS1's Avatar
well im not sure if it stalls all the way to 2800. secondly i want to get another so i can stall all the way. i want a ssf 3500. i doubt i was spinning. i heated them up nicely. completely stock suspension.
Old Mar 6, 2005 | 03:37 AM
| Powered by Satan |'s Avatar
what are your trap speeds?
Old Mar 6, 2005 | 10:36 AM
stevensLS1's Avatar
i believe it was 109
Old Mar 6, 2005 | 10:58 AM
WildBills Toyota's Avatar
should be a solid low 12 sec car. Get rid of those shortie headers and get some lts. Should pick up 20-25 more hp
Old Mar 6, 2005 | 11:29 AM
mattr228's Avatar
best i cut on my Goodyear Eagle GS-D3s was a 1.916 on my 12.89 @ 105 run
defintely need a stickier tire
