Security Light?
Old May 4, 2005 | 10:26 AM
obseSSed's Avatar
Default Security Light?
It's only happened a few times - but my security light is staying on. I dont have my manual in the car, so I haven't had a chance to look it up, anybody know what it means?
Old May 4, 2005 | 10:58 AM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
Usually it means that the Ignition switch terminals are not making contact with your key (that black pellet that is in the key). Sometimes you can clean the contacts with air/electric contact cleaner in the switch where the key goes and get it to live a few more months, but eventually you'll have to replace the ignition switch itself.
I've also seen the wires to the switch break apart and loose contact. That also will need the switch replaced. (Its actually called a lock cylinder/tumbler...etc.)
Old May 4, 2005 | 11:12 AM
Ben R's Avatar
Maybe you're just that damn ugly.
Sounds like warranty work to me.
Old May 4, 2005 | 11:20 AM
obseSSed's Avatar
thanks joseph. Where should I go to get it replaced? And how much?
i don't want to hear anything from you. I had a strange dream last night..something about a crazy *** ex and a 6 page letter. A huge permanent marker was also involved.
Old May 4, 2005 | 11:24 AM
Mr Powell's Avatar
http://www.vobra.org/vids/bonesaw.wmv
nuff said!
Old May 4, 2005 | 11:35 AM
obseSSed's Avatar
with a file name like "bonesaw" i really don't want to watch it...
Old May 4, 2005 | 01:29 PM
| Powered by Satan |'s Avatar
Originally Posted by Mr Powell
bwahahahaahahahahaahahahahahhhahahahahahaahhahahah ahaahahahahahahahahahahaahahahah
:breathe:
hahaahahaahahahaahahahahahaahahahahaha
nice powell
Old May 4, 2005 | 01:48 PM
01 Red WS6's Avatar
Mine has done that a few times. My car did it the 1st week I had it but I've never had a problem. I guess I just have the touch
Old May 4, 2005 | 02:31 PM
blakester's Avatar
My car did that a lot. Then sometimes when I would go to start it, the security light would come on and it would not start. I would have to wait like 10 minutes or so, then the security light would go off and it would start up. So just a warning this will probably start to happen to you as well. Both of the f-bodies I have owned did this to me.
Old May 4, 2005 | 04:52 PM
RamAirD98's Avatar
My security light has been on for over 12,000 miles and it has started fine every time. I guess it's been luck!
Old May 4, 2005 | 11:09 PM
LS1LUNATIC's Avatar
mine did it last week, cleaned the resistor, and bam! back in business
Old May 4, 2005 | 11:40 PM
A_W_O_L's Avatar
Me and my sister have gone through this....I just used the spare key that came with the car and that done the trick. Chances are that the switch/tumblers are worn some, but It may just be the key/pellet is worn too much. (keys are made of a softer material than the tumblers....in most cases) Like Joseph said eventually you will have to replace it. That being said, it has been over 2 years since mine done that and it's still working great and I havnt had to replace it yet.
Word of advice, if the spare key does do the trick, have a copy of that key (original) made and then put it up and dont use it, copies of copies of copies lead to trouble. kinda like MULTIPLICITY
Old May 5, 2005 | 09:08 AM
01 Red WS6's Avatar
when mine comes on I just pull the key and put it back in. Its always worked so far
