low coolant?
Old Jun 26, 2005 | 06:12 PM
WildBills Toyota's Avatar
Default low coolant?
my cars low coolant light came on about 2 weeks ago. I added like a 1//2 cup of water and the light went off. Now it cam back on. It must have some sort of small leak but i never see puddles or anything under the car. Is there a normal spot where these cars leak? what could it be?
Old Jun 26, 2005 | 06:44 PM
GoldRust's Avatar
LS1TECH Sponsor / 7 Second Club
Check for build up around the water pump.
Old Jun 26, 2005 | 06:51 PM
01 Red WS6's Avatar
I'll second the water pump
Old Jun 26, 2005 | 06:55 PM
thanks pimps
Old Jun 26, 2005 | 07:21 PM
SLPformula's Avatar
My low coolant sensor is bad cause i know its full and it has all new parts (water pump, radiator, cap, and thermostat) I just un plugged it.
Old Jun 26, 2005 | 10:32 PM
Inspector12's Avatar
TT-TECH Veteran
Radiator cap has gotten a few friends.
Old Jun 26, 2005 | 10:34 PM
NexGen's Avatar
look for signs of coolant around the overflow and the seams of the radiator
Old Jun 26, 2005 | 10:45 PM
LS1 Brent's Avatar
do you have the coolant bypass mod? It might come from there.
Old Jun 26, 2005 | 11:57 PM
DONAIMIAN's Avatar
look in your inner fender on the driver side and see if you have a bunch of **** in there, if so its time to replace that cap. Usually when the cap goes, thats where all the coolant ends up blowing out at.
Old Jun 27, 2005 | 12:10 AM
ex-SS-ve's Avatar
the passenger side you meant.
Old Jun 27, 2005 | 12:14 AM
DONAIMIAN's Avatar
yup, thats what i meant, thanks.
Old Jun 27, 2005 | 03:36 AM
electricz28's Avatar
I noticed mine when changing the oil-look for signs on the steering rack.
