Pool your tips for saving Gas.
Some things I've always wondered... does it make a difference where the ac **** is set? If its set at all the way cold does it use more fuel than if its closer to the cool/warm setting?
How about the fan level, is it better to turn the ac cooler and leave the fans low, or turn the fans up and put the ac temp higher?
Does having a 160 stat lower mpg? I would think so because it turns the fans on earlier right? Which would waste more fuel?
How about the TB bypass does that help or hurt mpg?
All of these seem like little things but when it costs .25 cents a mile to drive your f-bod...
Combine all your errands into one day, and try to get it all done in a specific area. It will limit the driving.
Eat out less, it will save you a lot of money.
so all of this and you could get over 300 MPG like my dad did
https://ls1tech.com/forums/showthread.php?t=374244[/QUOTE]
Thanks for the link
