question concerning 26 vs 28 inch tires??
my Nissan has a t350 tranny and i have 3.91 gear which let me top out at around 128mph at 7000rpm (tested this on the dyno) on 26 inch tires..
I know I will trap alot higher than that, so will 28 inch tires help me that much?? And will i lose some low end power if i do that?? im researching for some 3.73 gears, but this has to be some custom work..
thanks in advance for any help...
duy
duy
TT-TECH Veteran
28"W for sure I think the expanded diameter is like @ 32" so yeah you will pick up quite a bit and as far as your low end I don't think it is going to kill you at all, but you are gearing up so you could loose. You will just have to test it to know for sure, but I suspect with the brake that you won't loose anything.
Jeff
Jeff
