Help with A/F Gauge
Old May 29, 2006 | 08:58 PM
SuperGook's Avatar
Default Help with A/F Gauge
Does anybody know the pin# on the pcm for the signal wire for the o2 sensor is? It is a 2000 T/A M6 Thanks.
Old May 29, 2006 | 09:18 PM
SS SLP2's Avatar
The A/F gauge all you need in a 12v, ground, and the other wire goes and taps into the white wire on one of the O2 sensors , ( I will se if I can find the # and place I bought an adaptor which plugs into the 02 and has a pig tail which you may connect on to without having to cut into any wires, if I find it I will getback to you ) good luck Johnny
Old May 29, 2006 | 09:20 PM
SuperGook's Avatar
Thanks man, I appreciate the info.
Old May 29, 2006 | 10:55 PM
Pwebbz28's Avatar
There are letters on the plus of your o2's. My 01 TA had the factory 02's and it used the purple wire(letter B on the pigtail). When i got my aftermarket ones it had 2 whire wires so just go by the letters on the pigtail unless you just gotta do it on the computer. I didnt because i didnt wanna cut the factory wires so i cut the wire on the sensor.
Old May 29, 2006 | 11:57 PM
kyles2000z's Avatar
you can also wire it to the pcmon pin #10 on the lower connector
