Old 06-24-2006, 08:06 PM
B-RAD2's Avatar
Exclamation ???
Ok i have posted in a few other forums and got no response. i know i can depend on my fellow TEXANS. I am putting the LS7 clutch in my car on sun. My question is what is the best fluid to put in it????
Thanks,
Brad
Old 06-24-2006, 08:09 PM
ex-SS-ve's Avatar
just use the dexron III transmission fluid . should work great. hey let me know how you like the clutch. im buying one soon possibly
Old 06-24-2006, 09:36 PM
B-RAD2's Avatar
Anyone else??
ex-SS-ve i will make a post about it once it's installed!!
Old 06-25-2006, 09:48 AM
98OCT/A's Avatar
Post when you install it, im also looking into it
Old 06-25-2006, 09:54 AM
JETG's Avatar
dexron III transmission fluid is the most common, you can also use red line products. But I would just use the Dexron
Old 06-25-2006, 10:16 AM
Angus's Avatar
Uhhh, fluid for a clutch...
Old 06-25-2006, 10:29 AM
JETG's Avatar
search feature is your friend, here is a poll for fluid that people use
https://ls1tech.com/forums/showthrea...t=clutch+fluid
Old 06-25-2006, 10:33 AM
ex-SS-ve's Avatar
on the master cyl/slave cyl side . i always flush mine out of the stock fluid. clean it with brake cleaner and then do a final flush with alcohol. and then i put some dot 5 silicone brake fluid in there. definately a better pedal feel even more so when the car gets hot.
Old 06-25-2006, 12:38 PM
AGRV8D's Avatar
wont that tear up your lines?and small ruber inside the the master/slave assy?
Old 06-25-2006, 07:33 PM
SLPformula's Avatar
i use mobile 1 but thats my pref.
Old 06-25-2006, 08:26 PM
ex-SS-ve's Avatar
nope. thats just the right procedure before you put in dot 5 fluid. because its not compatible with the dot 3 thats in the car stock.
Old 06-25-2006, 09:01 PM
chadtx01's Avatar
I've been running the O'Reilly brand DOT4 and I have had good luck with it. I didnt feel like flushing my lines or I would've gone with DOT 5.
