Major Lightning PROBLEMS!!!!
Old Jul 30, 2006 | 03:35 AM
ls1_cam2's Avatar
Default Major Lightning PROBLEMS!!!!
Tried to install a diablo tuner on my friends 00 Lightning and once I tried to install the tune the truck would not turn on and now it just sits there and the crank turns but nothing. Wondering what could be wrong with it. Think maybe the ECU f'ed up or something so can we just buy another one and just unplug the old and plug the new??? Need HELP!!!!!!!
Old Jul 30, 2006 | 07:32 AM
A-Bomb's Avatar
The same thing happened to my brothers truck a few years ago. Somehow his ECM got screwed up and he had to get it replaced.
Old Jul 30, 2006 | 10:59 AM
ls1_cam2's Avatar
Do you know how much a new EC was and how much to install????
Old Jul 30, 2006 | 11:07 AM
TEX02SS's Avatar
this happened to me several times while hyperteching my 01 sierra....actually never could figure out the problem. The hypertech would just freeze up in the middle of the upload. I had to have it towed into the dealership twice and have the pcm reflashed. Then sent the unit off to hypertech to have it reset too as it had my 'stock tune' in its memory instead of the hypertech tune. Hypertech even sent me a new one and it still messed up. I got it to work once and finally gave up on it and got a Wester's PCM. It sounds like the lightnings pcm simply forgot how to start. I'd just take it to the dealership and have them flash the stock tune back on it. That should fix everything. And next time you try the diablo i'd do it in the parking lot of the dealership so if it does it again, you dont have to go far to fix it. Hope this helps.
Old Jul 30, 2006 | 11:46 AM
imnotplutonium's Avatar
Yea happened to my buddies silverado a few months back. used the predator and then his computer crapped out. He had to buy a new one or had his shipped off to get reflashed by a tuner.... cant remember but he had to take it out.
Old Jul 30, 2006 | 12:24 PM
Sprayed1998's Avatar
clean the contacts GOOD, might even wanna sand them down a bit, this happens alot and most of the time it is a bad connection. Is the chip SCT?
Old Jul 30, 2006 | 12:58 PM
ls1_cam2's Avatar
Ok i will try cleaning the contacts and maybe even sand them. Next HUGE question how much does it usually cost to reflash the PCM???
Old Jul 30, 2006 | 04:31 PM
redz_02's Avatar
Can you send the stock tune back to it? I would give diablo a call. I would also try updating the tuner, you can get the update from the diablo site you just need to go to radio shack and get a wall plug in and a pcm hookup.
Old Jul 30, 2006 | 04:34 PM
ls1_cam2's Avatar
Tried to turn it back to stock and the POS just tells us that it can not detect/verify the type of vehicle its on. Anybody know how much it usually runs to reflash the EC???
Old Jul 30, 2006 | 04:44 PM
thesource's Avatar
Did you remove the fuse for the fuel pump ? Sometimes it will blow while trying to tune it . I believe its #10 on the fuse panel .
Old Jul 31, 2006 | 03:10 AM
ls1_cam2's Avatar
Didnt try that but will check right now and see what i get.
Old Jul 31, 2006 | 11:11 AM
TEX02SS's Avatar
they will charge you for 1/2-1 hour of labor unless you have a hookup. Just depends on the shop rates. I remember paying $50-$70.
Old Jul 31, 2006 | 10:31 PM
ls1_cam2's Avatar
**** thats what I am talking about finally got somebody that knows the price to reflash.
Old Jul 31, 2006 | 10:36 PM
ls1_cam2's Avatar
Default Called PREDATOR
called predator and got no f'ing where. They just put me on hold for like an hour so i called again and the same **** again. WTF do I do now???
Old Aug 2, 2006 | 11:00 PM
PoorSVTMan's Avatar
i know this thread is a little old, but ditch the diablo and go with sct but having a Lightning i figured id post up anyway...
ANother thing you have to do with diablo is make sure NOTHING is on while you are flashing the ecu. Keep doors shut so dome light,etc isnt on, turn radio off, etc... This is a common thing that diablo predators do... That being the reason i went with sct. Also your supposed to pull the fuel relays under the hood while loading a tune as well.
Any other questions just ask..
