LS7 question?
Old Dec 18, 2006 | 04:27 PM
lets_fly's Avatar
Default LS7 question?
i am going to put a LS7 clutch into my 02 TA, i have heard i will need the LS2 flywheel, is this true? if i have to change the flywheel, will a spec billet steel do the job? i am getting the parts on wednesday, so fast responses will be appreciated. thanks
Old Dec 18, 2006 | 04:40 PM
KingSS's Avatar
the LS7 clutch requires an LS2 style flywheel to work correctly.
Old Dec 18, 2006 | 04:42 PM
lets_fly's Avatar
so i guess the spec will not work?
Old Dec 18, 2006 | 04:53 PM
Tobynine9's Avatar
I wanted to use Spec's LS2 aluminum flywheel when I put in my LS7 clutch. I talked to two different techs at Spec and both said it would NOT work. I guess their LS2 flywheels are set up to only work with the Spec clutches. I don't know the details, that's just what I was told several times. I'm assuming it's true as I was all but standing there with money in my hands begging for a flywheel.
Old Dec 18, 2006 | 04:57 PM
lets_fly's Avatar
ok then, i guess LS2 flywheel it is. any other opinions, i have till wednesday. lmk
