Car won't start! I was on my way to a meeting, and I tried to crank it up and it didn't even try. The accessories all came on and when I left the key in the ignition, the security light was on, but that is it. Any ideas? |
Broken ground in the steering column. |
well if this isn't weird - I searched the forums and some people said it may be the key that is dirty. It didn't look dirty, but I went ahead and cleaned it anyway. Sure enough, it started right up! Now here is the new problem: The security light still stays on while driving! Any ideas? |
Could be a ton of different things, when you turn the key forward whats the volt gauge do? |
i'll have to check that out and see what it does. I did just buy a new key and that didn't help at all. |
disconnect your battery for at least 10 minutes and let the computer reset!! that should clear it up!! |
thanks hoosier! have you had this problem before? |
No Problem! I personally havn't, but a friend of mine had it! 02 T/A same situation! |
I had that problem. I ended up having to have the whole ignition tumbler replaced. Not cheap. -Mike |
Hey Mike, can you tell me more about what happened and how much it was? edit: woohoo! 1,000 posts! |
I've had that happen to. Try 2 things first unlock the doors with your keyless entry and then close em and then try cranking it, also try cleaning the key with rubbing alcohol. Sometimes it gets dirt and stuff in the ignition. If that doesn't work do like the other guy said and disconnect the battery for 10 minutes |
Originally Posted by nomorews6 Hey Mike, can you tell me more about what happened and how much it was? edit: woohoo! 1,000 posts! |
you will never guess what happened - i disconnected the battery for 15 minutes, reconnected and restarted. It came on for about 20-30 seconds and then shut off! Woohoo!!!! I shut down and started up again and while it was the last light to turn off, it still turned off. I think I am good now! Thanks so much guys. |
Yah, i am guessing it is something with your alarm. I had the same problem with my car a while back. The alarm just needed to be reset. I am glad that it all worked out for you! |
Originally Posted by nomorews6 you will never guess what happened - i disconnected the battery for 15 minutes, reconnected and restarted. It came on for about 20-30 seconds and then shut off! Woohoo!!!! I shut down and started up again and while it was the last light to turn off, it still turned off. I think I am good now! Thanks so much guys. |
Originally Posted by nomorews6 Hey Mike, can you tell me more about what happened and how much it was? edit: woohoo! 1,000 posts! -Mike |
Originally Posted by hoosierdady76 disconnect your battery for at least 10 minutes and let the computer reset!! that should clear it up!! |
| All times are GMT -5. The time now is 04:13 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
