car wont start
Old May 3, 2007 | 10:01 PM
onebadblackz's Avatar
Default car wont start
well this morning I went out to start up the car and when I turned the key over it did nothing, the battery and everything else is fine but after about a couple of trys I wiggeled the key a little and it started up so I killed it and tried again and it just did nothing. What does this sound like to you guys? Has this ever happened to anyone else before? If so what did it turn out to be?
Old May 3, 2007 | 10:11 PM
Randy_S's Avatar
The simplest guess would be loose wire going to the starter or ground.
If not, then possibly the ignition switch.
Old May 3, 2007 | 10:36 PM
Donohue96M6Z28's Avatar
maybe a bad clutch safety switch?
Old May 3, 2007 | 10:37 PM
or maybe loose battery connections?
Old May 3, 2007 | 10:57 PM
FIREHAWK #07's Avatar
had this happen to me not too long ago.... took a 10mm and tightened the loose ground wire...
Old May 3, 2007 | 11:43 PM
I'll check out the starter connection and then go from there
Old May 3, 2007 | 11:58 PM
LT1wannabe's Avatar
If the security light came on, it's easy....that "chip" in your key didn't line up right in the hole.
Old May 4, 2007 | 12:00 AM
didnt "line up right"? or your vats is going out.
Old May 4, 2007 | 12:16 AM
ya what do you mean not lining up right?
Old May 4, 2007 | 02:03 AM
thats what lt1wannabe said.. Im not sure what he meant?
Old May 4, 2007 | 12:59 PM
well I'm about to leave to get me a new key hopefully this will fix it... I believe it will because the security light has been on for the past 2 weeks.
Old May 4, 2007 | 01:04 PM
ttt...
