How not to park your Mustang.
Moderator
Originally Posted by Daez
I didn't pay TOO much attention, but it looks like a new mustang.. even the v6's on those have some power.
ok guys, where did/does it say the car was a manual...? assumptions anyone...
second, a CMU wall is not required (unless dictated by building code(s)) to have rebar for extra reinforcement. CMU is very strong in compression but not in tensile strength. PENGU...you are correct, CONCRETE walls are supposed to have and do have rebar for reinforcement, however this is CMU, such is not the case unless stated with what i wrote above. also, there was no REBAR witin the CMU, otherwise you would see bent bars. safety cables are usually installed on the inclines/decline ramps of a parking garage if it is enclosed like the one in this case and are required by code. we do not know if bump stops are in the garage. only parking structures that are exposed to the elements would require by code to have safety cables and bump stops to prevent a car from going over the edge. then again that might not stop all cars, there are too many factors that even with these safety devices in place, a vehicle could still go over the edge...
third, for none of you being there, how do any of you know they were skid marks and not peel out marks...? skid marks for braking peel marks for acceleration. regardless of what the news says, how accurate are they really. reporters mess up all the time...
fourth, for the guy who replied the 'All American Comment' to SUE. if the building is grandfathered in, and there is no new construction (re-model/tenant improvements are exempt), then there is really no lawsuit to be had. the building being grandfathered in makes it compliant to the codes. New construction would then mean that everything would have to be updated to meet current building/fire/safety codes...
fifth, since CMU is not strong in tensile strength, it would be estimated that even going 20mph or more would easily send the car though the wall (alot of people can reach 20mph in no time in a parking garage). also, since we do not know the layout of the parking garage floor, we cannot say for certain what/where exactly the driver was located in regards to the over all garage...
its a freak accident, and unfortunate that a life was lost, but before shooting off a bunch of BS responses, theories and blame shifting (IMO), everyone should stop for a second, think and educate themselves. the blame falls on no one but the driver at this time, unless police reports and evidence prove otherwise...
SSwt - It sounds like you're pretty familiar with the building codes in Texas. I'm not as familiar with them as I am the ones in California where I work, but wouldn't any building over 4 stories require reinforcement by todays standards, whether it's CMU or not? Now I get that this is an old garage and isn't required to hold up to todays standards, but I was just curious about your comment itself.
#32
Are you a defense lawyer. If not you might want to give it a try. That was pretty ******* good.
#34
Maybe he wanted to wreck his car & wanted it to look like a clutch accident or hitting the gas instead of the break. But instead of the wall just smashing the car, it busted open
#35
Also, the point at which using CMU, reinforcing it, and then filling with concrete to provide a reinforced wall would surpass the dollar amount of simply using either a cast-in-place reinforced concrete wall, and as well as a pre-cast reinforced concrete panel wall construction (more commonly known as tilt-up construction)...
Further, the type of construction used for a specific structure/building still means there are many different methods/ways that such said structure can be desined/built. as long as it passes all codes (state/local) and gets issued permit for construction, up it goes...
as for the character who told me to chill, some were stating opinions, others were making assumptions off of no information. in regards to my inital reply, my comments were ment to make people think about all the factors that come into play (as i myself have designed parking garages/structures), hopefully prior to them saying such things as, "I guess he popped the clutch", which is an assumption based comment, and to help answer as to, "Why is there no REBAR?". i simply was trying to inform the masses with even the small amount of knowledge that i have as a result of my profession.
