i hate optis(venting)
Old Aug 25, 2007 | 03:30 PM
95LT1963's Avatar
Default i hate optis(venting)
well i found that my opti was goin bad so i orderd one from acell got it in (after 2 months of back order). Should have known then to cancel it and get a diff brand...well got it in and one of the mounting holes that bolt to the block were broke off and the opti was so hard to spin like the bearing were 100 yrs old. I pulled it apart and the metal wheel(i think its called a relucter wheel, or optical wheel..corrcect if wrong trying to remeber) but it was bent all to ****. Sent it back to orileys. they got me a new one in on the next fri. Hook it up and the car wornt spin back 3,000RPM... and idles rough and back fires alot. so i put the old otpi in and runs fine. well runs fine for 30 mins and then it gets hot and starts to brake down and run shity. so i am a stand still so im letting the car sit for a couple days till i get the MSD BILLIT ALUM in...and the only reason im letting it sit is cuz just spent all my money on the msd and no money for gas ...haha
sorry for rambling just agravated
still gata love the LTx's tho
Justin Reynolds
Old Aug 28, 2007 | 11:18 PM
CAMAROWITHBASS's Avatar
suckks
Old Aug 29, 2007 | 12:29 AM
ZONES89RS's Avatar
In-Zane Moderator
Man i wish i could afford a Del-tech, cure all.
Old Aug 29, 2007 | 12:43 AM
rayosequis's Avatar
Well, it is and isn't. I just finished installing one on my Vette and your opti has to be good, if it goes out or is going out, it won't trigger the Delteq to fire. If you keep your eye out, you can probably find one for cheap. I picked up mine on craigslist for $450.
The Dynaspark completely replaces the opti and is a true cure all, but they are pricey.
Old Aug 29, 2007 | 02:34 AM
ZONES89RS's Avatar
In-Zane Moderator
Yea, i found a Del for 450 on Ebay, but you can get them off of northstar motors in caddys.
Old Aug 29, 2007 | 04:42 PM
im sitting here at work processing the returns, and guess what was on the pallet of defectives that came in?
haha the same unit that gave you hell, now i gotta send it back to Accel.
BTW Accel sucks ***, they have the highest defect rate of all the ignition products we sell..
Old Aug 29, 2007 | 05:59 PM
rayosequis's Avatar
Wouldn't you still need the "opti-box" and harnesses to make the coils work correctly ? Or are these all Northstar parts ?
-Ernie
Old Aug 29, 2007 | 06:23 PM
95LT1963's Avatar
DONE!!!!
i jsut got the MSD put on the car and it runs great!!!
i also put some TR6s in it with new 8mm wires, and well i took the exhaust off the stock manifolds and well i soaked the bolts in penatrating oil and i got 4 of the bolts of and BROKE 2 , well took it to the exhaust shop in den and well he heated the studs up and got them out. put me some new one in and i was good to go, or so i thought. when he had heated and welded the removing bolt to the stud it burnt my brand new wire for cylinder # 7 , well went and bought a brand NEW set of wires and just used the one for #7.
well all in all the car has never ran better then today...parts list now
MSD billit opti
water pump
NGK TR6s
8mm wires
Accell coil
ignition module
..and a spare set of wires(damnit)
Justin reynolds
were did that accell opti said it was returned from ...if its Denison Tx..than thats me ...hahahah...
Old Aug 29, 2007 | 06:27 PM
WS6NIGHTMARE's Avatar
-Ernie
No, he means the coils can be had from the NS Caddy. You need a few other parts. The Delteq only eliminates the high input signal, which is the cap and rotor, the part that 9 times of 10 goes bad. If your low side signal, the sensor, is bad, then the Delteq system will not work....ask me how I know.
I may have the signal thing mixed up, but you get the idea.
Old Aug 29, 2007 | 10:36 PM
accoring to this paper if your name is Jose M***** M****** then it is what it is.
Old Aug 29, 2007 | 11:27 PM
crAzy95Z28's Avatar
Default plug wires?
hey what color are they? If they red i might need just ONE sooner or later as the alternator belt rubbed against one and kinda rub some rubber off of it...
If its the ones you put together then yea ill take one off your hands here pretty soon. Pretty dumb to go out and buy a whole box for like 80$ for one you know?
Let me know man.,.
