F\S TH-400 3200 converter and stuff
I have a th-400 with transbrake and reverse manual valve body good to 1500 hp. The converter is a 3200 stall speed has anti balloon plate and fits directly into ls1\ls2 crank without an adaptor. Pro rachet shifter that bolts into the stock location that the shifter is in now. Transmission cooler and all a\n lines and fittings. Northwest drivetrain drive shaft with heavy duty yolkes and sealed spicer bearings. Drive shaft adaptor for solid driveshaft 04 or 05, 06 model. Transbrake button and cord. TCI sfi TH-400 flexplate for ls1\ls2. Everthing you need to convert your GTO to a Turbo 400 set up with solid driveshaft. This setup has only 4,200 miles on it and functions great. Selling the hole setup for only 2500.00 or will posssibly discuss trade for a six speed with short throw shifter and twin disk clutch.
