c6 vert
and a few videos to go with it.
http://www.youtube.com/watch?v=R2o7k4Cbou0
http://www.youtube.com/watch?v=QjusBLAR3qs
http://www.youtube.com/watch?v=z3gtMpupels
Stainless Steel Main Girdle from DM performance
Callies Dragonslayer Crank & Compstar I beam rods
Manley Forged pistons @ 9.5:1 compression
CNC AFR’s 225 heads Comp cams hardened pushrods
Comp Cams Bump-stick, stainless rockers & roller lifters
Comp cams 921 dual spring and titanium retainer kit
ARP Main and Head studs
Cometic gaskets
8 rib ATI balancer, power steering pulley, alternator pulley
B&M short throw shifter
Aeromotive Fuel Rails and Regulator Aeromotive fittings and lines from fuel tank to fuel rails
DeWitts Aluminum radiator
Custom aluminum radiator mounts,
LPE 100mm mass air flow sensor
External Heavy duty Hayes engine oil cooler with 200* thermostat installed
Mezier electric water pump@ (160*) thermostat
Excedy twin disc clutch
Dynatec 1-7/8 Headers
Corsa Sports
3/8 tunnel plate for extra rigidity and tunnel heat insulation
Hardened right and left output shafts
C6 Z06 Brake system, Pfadt coilovers
Z06 rear sway bar
Battery relocated to rear Compartment
Triple A pillar gauge pod with Wide band AFR, fuel pressure, boost gauges
LPE hood
Wide Body - rear and front fenders
I forged FS Classics 18x9.5”F 19x13”R with the Hoosier R6‘s- 19” 345/30/YR19
M20 Extreme Laser Jammer
DPE - Custom wide Z06 front Fascia with no scoop
Computer programmable Alky system
Procharger D1SC Superchager kit with DPE custom 8 Rib setup and tensioner mod
HP tuners integrated into the car for tuning/logging using cars touch screen PC
Full function Windows XP pro integrated . Music videos on the fly, surf the Internet, etc.
Front and rear cams permanently mounted for one touch PIP Video recording for 12+ hours of racing or road footage
Motion detector activation can record when someone approaches your car activating front and rear cams
