need quick help: removing a door.
Old Jun 20, 2008 | 06:10 PM
ckyconan2003's Avatar
Default need quick help: removing a door.
I am removing the door off of my honda and swapping it with a new one. But, in between the two hinges is what seems to be a third hinge but i cannot remove the pin the is holding the hinge in. i can only get the pin half way out then is stuck. do i need to pull harder or is there some trick to removing this pin?
Old Jun 20, 2008 | 06:28 PM
no_more_z28's Avatar
did ya try spinning it while u pull on it?
Old Jun 20, 2008 | 08:12 PM
LeadfootDuramax's Avatar
Get a long punch and a hammer. If you get to it from the other side....just drive it out. It is prob in a bind so that isn't helping.
Old Jun 20, 2008 | 11:26 PM
Manic Mechanic's Avatar
If you want we can line up and I'll blow it off for you.
Haha, couldn't resist.
Vernon
Old Jun 22, 2008 | 08:07 AM
Trev_SS's Avatar
lol i agree what happened to the f-body man, i will say you probally are enjoying the gas mileage in that thing though
Old Jun 22, 2008 | 01:40 PM
Vernon
LOL Whats up man? I head you converted your truck back and quit running E85??
Old Jun 22, 2008 | 02:02 PM
Mike96z's Avatar
why remove the pins? does it have brackets like the fbody? If so just unbolt the brackets with the door.
Old Jun 23, 2008 | 07:16 AM
Yeah, it was never a costs reduction mod. It was a power mod good for 20-30 with the 496. With fuel prices getting so high I cut expenses. My kids moved back in with me so I was running them to school etc and my travel doubled. I also found the plugs had fouled out from being too cold for E85, they were colder than stock. But I only gained about .5 MPG on fresh ones.
All I had to do was reduce fuel pressure for straight gas with the larger injectors, I can run either anytime I want but I'll wait for the price of E85 to go down for now. At Kroger it's always $0.30 less than gas with a 20% + drop in MPG.
Vernon
