Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Welder Question (Picking a...)
Old Dec 19, 2003 | 10:33 PM
2KThunder's Avatar
Default Welder Question (Picking a...) (links fixed)
I need a welder that would be able to weld a catalyic convertor on. I have no clue when it comes to welding (I wont be the one doing it, I just need the equipment.) I kinda understand the concept. But I dont understand the thickness and strength of the weld and the processes used (Mig Tig Arc). Would this welder work (for a cat):
http://www.homedepot.com/prel80/HDUS...ceffdfgidgmk.0
(The first one on the page)
Or would I need something like this:
http://www.lowes.com/lkn?action=prod...00001703-K1170
Or something more expensive. I am clueless, can someone shed some light on the subject (and remember, I am just purcahsing the welder, I would never attempt to weld)? Thanks,
John
Last edited by 2KThunder; Dec 20, 2003 at 10:32 AM. Reason: Fixed broken links (again)
Old Dec 20, 2003 | 12:34 AM
ta12sec's Avatar
I cant see either link but, I think it would be cheaper to just get a muffler shop to do it.
Old Dec 21, 2003 | 12:49 AM
Keith's Avatar
For exhaust work a 115 volt mig welder would be the best IMO. Try and get the most amps that you can for future versatility. Look on spending close to $1,000.00 for everything. (bottle, mask, wire, tips, etc. )
Old Dec 21, 2003 | 07:22 AM
mitchntx's Avatar
A 110V MIG rig would probably do you jsut fine.
Tractor Supply has a Hobart125 for ~$370 and it comes with regulator for gas, gun, wire ... basically ready to go. Hobart is a consumer version of a Miller.
It should be OK for home use and metals up to 1/8" thick.
Old Dec 22, 2003 | 04:13 AM
2KThunder's Avatar
But go for MIG, Arc isnt what I need....
Old Dec 22, 2003 | 11:20 AM
PlainwhiteZ28's Avatar
The basic difference in a MIG and an ARC welder is that the MIG uses an inert gas as the flux which leaves a cleaner weld with no slag. The ARC uses a flux on the stick which leaves slag that must be cleaned up.
I think a nice mig is the way to go, but my dad who is a professional welder only deals with stick welders..........I think hes just old school
Old Dec 22, 2003 | 01:18 PM
2KThunder's Avatar
Weld look doesnt matter much, price does. I just need whatever can get the job done without spending too much.
Old Dec 22, 2003 | 02:20 PM
Then have an exhaust shop do it,
no need in buying a cheap welder.
Money shouldnt be held back on tools.
Old Dec 22, 2003 | 06:46 PM
DARK AGE 53's Avatar
Something like this would work quite well, http://www.lowes.com/lkn?action=prod...8-1703-K2159-1 .
Al
Old Dec 24, 2003 | 07:56 AM
mitchntx's Avatar
What I suggested IS a MIG welder
Old Dec 25, 2003 | 11:50 PM
2KThunder's Avatar
I didnt mean it like that, I meant : So I should go for mig over arc.
Old Dec 31, 2003 | 08:23 PM
NRC-Motorsports's Avatar
if your going to buy a welder nowadays yes it should be a mig,because if you decide you ever want to weld thjings to your car like a roll bar or whatevr arc welding is not allowed anymore, plus for an inexperianced welder its better to have the mig, like your dad i always used an arc welder but in the 80,s nhra said no more have to be mig/tig. but if for only one thing save the money go to muffler shop
