Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Ideas for Transmission upright stand??
Old 12-30-2017, 08:49 AM
epfatboy's Avatar
Default Ideas for Transmission upright stand??
Anyone have ideas for a upright tranny work stand?
I'm thinking on a metal garbage can with a 3/4" piece of plywood and a hole cut into it then just drop the tranny in tail first to hold it at a decent hieght by using whatever diameter hole works.
Gonna start working on a 4l80 soon and looking for better ideas if possible.
Old 12-30-2017, 11:45 AM
Received 3,018 Likes on 2,349 Posts
Actually, your idea sounds like it oughtta work! Lo-bux to boot!
Old 12-30-2017, 11:58 AM
98CayenneT/A's Avatar
I used a cheap hot water heater stand like this.
https://www.homedepot.com/p/Eastman-...FU9nAQod24gB9w
Cut a hole in the middle with a hole saw so the out put and input shaft can fit through.
Not the best pictures but should help.
In the second picture in the bottom left corner you can see the hole through the rags.
Old 12-30-2017, 12:35 PM
epfatboy's Avatar
Loving the living room feeling to the workshop you built, fireplace and carpet was a real nice touch that really brought it together 😎
Old 12-30-2017, 01:36 PM
epfatboy's Avatar
Also I was looking to stand the case up. I'm told it Makes dropping in and alignment of stuff a little easier.
Old 12-30-2017, 01:41 PM
It will work for standing the case up. That's what the hole is for. Once you start assembling the transmission you stand the case up and the out put shaft will go through that hole and you just build from the bottom up.
Here is a picture of my case standing up. Although it's empty you can see what I mean.
Don't mind the type, these are pictures from my build thread.
Old 12-31-2017, 08:46 AM
epfatboy's Avatar
Got it. Thanks for sending that along.
Old 12-31-2017, 06:18 PM
Krom's Avatar
5 gallon bucket, and a flex plate free
motocross bike stand $31
https://www.ebay.com/itm/Motorcycle-...9ZUgfb&vxp=mtr
ebay trans holding fixture that mounts to your bench, and rotates $120
https://www.ebay.com/itm/GM-Transmis....c100005.m1851
Old 01-02-2018, 08:16 AM
Restricted User
JoeNova's Avatar
Build a square stand out of $9 worth of cheap 2x4.
I can slide a 2 gallon stainless steel bowl right under mine.
Old 01-02-2018, 08:54 AM
squarles67's Avatar
I made a jig from angle iron to use with my engine stand. It can be rotated flat to put the valve body on and even upside down if you want.
Old 01-02-2018, 06:50 PM
epfatboy's Avatar
^^^^^ really like this!
Couple of pieces of angle stock and i can set it up on a old engine stand I have hanging around.
Old 01-23-2018, 09:11 AM
Heat Seeker WS6's Avatar
Here- http://www.ebay.com/bhp/transmission-fixture
Mounted to a bench that's secured to the floor, you can now rotate the trans to any position you want
Old 02-04-2018, 01:33 PM
epfatboy's Avatar
Decided to go ultra cheap and easy...
https://photos.app.goo.gl/k57Kotdyk4qFrOgm2
Bench is constructed from 2" rough cut and I buried the base plate with 4" lag bolts and I welded a nut to the back side of the plate so securing the angle iron via bolt was easy after I bolted the angle to the bell housing
Old 02-04-2018, 07:14 PM
Cheap, easy, and EFFECTIVE! Nicely done!
Old 05-22-2018, 10:53 AM
jetech's Avatar
I repurposed some metal from an exercise machine. I never liked that thing anyway..lol
I just put the hoop in the hydraulic press to hold it or clamp it to the work bench.
Old 05-22-2018, 12:38 PM
Exercise machine?!?!?!? Well anyway, it now serves a FAR more honorable purpose! lol
Old 05-22-2018, 02:32 PM
2ToeRacing's Avatar
We use an old torque flite 8 case
Quick Reply: Ideas for Transmission upright stand??
