Will brazing aluminum hold 12 psi of boost?
I'm about to install an intake air temperature system that came w/ an aluminum bung
I do not have a DC Tig welder for aluminum, but saw on youtube that you can braze aluminum and it's decently strong.
Would brazing the bung into my charge pipe hold for 12 psi of boost?
Thanks
Thanks
That isn't brazing
brazing is with brass
that is a glorified solder joint that you could easily break with a pair of pliers or a quick hit with a small hammer
just take it to a shop with a.c. tig welder and if you've already cut and fit the bung they will charge like 30 bucks
What a joke! Neither welding nor brazing! Welding fuses the parent metal with filler, brazing uses brass rod. NO exceptions!
Actually brazing is used for all types metals not just brass and you can braze aluminum. Brazing doesn't melt the base metal so it's a somewhat weak joint but should be able to hold 10-20 pounds of pressure if done correctly. I used the braze metal roll cages together for my RC cars/trucks and they would take a beating and never came apart. The trick is to find the filler that will in basically hold to the base metal being used.
The term "brazing" has to do with the filler metal, a brass alloy. If that is not the filler metal, it ain't brazing...
You can buy brazing rod in Aluminum Copper Brass and many others.
Brazing - The American Welding Society (AWS ), defines brazing as a group of joining processes that produce coalescence of materials by heating them to the brazing temperature and by using a filler metal (solder) having a liquidus above 840°F (450°C), and below the solidus of the base metals.
Gotta love newer tech! How long has this been around? If you say more than 30 years I'm gonna feel REALLY OLD! lol
