Looking for a 180 male to male 6an
Fellas. I need to make a reliable, compact loop in my power steering line. I deleted the cooler and looping a piece of hose has proved to not be a good idea. It leaks. Plus where it’s at, it’s too tight of a loop for rubber hose. So I’m looking for a 180 degree 3/8 to 3/8 barb (6an to 6an) that I could use to loop it. I’ve had no luck. I’m looking for something like this with males on each side
Or if you insert a spring inside the rubber hose, that will prevent it collapsing for tighter turns.
