Power steering pulley tool Questions?
Hello i am looking for a power steering puller/pusher to uninstall and reinstall a new PS pulley on my Powersteering pump. Is there a special tool needed for our cars? Does anybody know a place were i can order one online? Also does anyone have picutures on what the tool is sopose to look like. I went searching around some part stores but couldnt find one. I only find a 2 jaw puller type that only can be used to remove the pulley. http://www.partsamerica.com/ProductD...tnumber=648460
I only found this one at the local part stores.
Thank you very much.
I'd say it will work fine....
For the installer, you may need to cut of the 5/16" UNC thread section at the end.. The thread inside my PAS pump is 3/8" UNC, so I'd need to do the same
See pic enclosed of all the parts.
Its real cheap, but appears very similar to the one I purchased from MAC Tools:
http://www.harborfreight.com/cpi/cta...emnumber=40749
Once the tool is installed, pulley removal will look like this:
Left hand item in the picture.
It is threaded 3/8" for most of its length. The tip however is only 5/16". This will not screw into the threads in the PAS pump, as the pump is 3/8"UNC
These are the threads used for pulling the pulley onto its shaft.
