What's a decent size for a compressor? I'm looking to do mainly air ratchets, impacts, and minor stuff like nailers/sanders. Is a 20gal enough? What about if I wanted to sandblast? Would that require a step up? Like a 50+? Thinking about a ~5hp 20-25gal setup. Home use, not a shop. Don't want to waste my money and get some underpowered POS, but don't want to go crazy either. Dope |
ive blasted with our 5hp 25 gallon, you have to wait every so often, but for most air tools, its plenty. If i was doing lots of blasting, lots of impact wrench, etc, i'd get a bigger one. If you're gonna use a DA sander alot, get a bigger one, for some reason they use LOTS of air.. olly |
Get the biggest you can possibly afford. Avoid and oil-free compressor (I have one... they are noisey and do not have the service life or duty cycle of a traditional pump). My current 32 gal 110v Husky is okay, but when it dies, I plan to get serious with an IR 220v (~15cfm) and at least 60 gal. |
The bigger the better. Its something that will last you forever. |
This is just a weekend project kinda thing, nothing super long term or fancy. I wanted a 20-25 because they are relatively small and portable, whereas something like a 60 would require 220 and a more permanent install. Not to mention the initial cost. Then again, doing it right the first time... Dope |
I think mine is a 30 gallon and I think it seems to run out of air pretty quick especially when trying to use air grinders and stuff of that nature. |
I had a 30 gallon oil-free compressor, but when it came time to use a DA sander, HVLP gun, and different tools that require more CFM it was limited. I went and got a 60 gallon and so far it has proved to be all I need. A 90 or bigger would be nice, but a 60 is really all I need. Also, the 220v is not that hard to do, it's not as "permanent" as you think it would be. It's a judment call and it's alot like buying a cam, once you buy one, you'll wish you got a bigger one. |
Ended up going with the 60. It was only $80 more. Thanks guys. Dope |
60 is the way to go. Bigger is better. |
Holy shit, I didn't realize how massive this thing was gonna be. It weighs 250-300lbs and is as tall as me. If I ever run outta air then I'm doing something wrong! Dope |
go with a 60gal atleast |
Good choice. What brand? |
Ive got a 2 gallon. Yeah you read it right! It will run an air tool...IF you feel like waiting for it to pump up between every bolt! :jest: |
Originally Posted by rushman Good choice. What brand? Got it for $380 shipped through a crazy deal at amazon (it was 580 before), as well as a dewalt reciprocating saw and a black and decker jigsaw and a 50' airhose. Only a $30 rebate too, the rest were coupons and promotions. Dope |
30 gal 2.5HP at harbor freight right now for 150.00. Looks decent for the weekend worrier. |
CFM isn't high enough on the 30 gal/2.5hp is it? |
I have a craftsman professional 30 gal/6hp oil lubed. I bought it for about 400, it was worth the money though. Don't get a oil free a/c they are alot louder and don't last nearly as long. |
The tank sicze isn't the only thing to consider. You want to keep the cfm above5.5 or so @90psi or you will be like the guy above with the 2gal. (no offense) |
Originally Posted by greatwhitess The tank sicze isn't the only thing to consider. You want to keep the cfm above5.5 or so @90psi or you will be like the guy above with the 2gal. (no offense) |
Don't get a Craftsman, Campbell-hausfeld, or any other cheap brand, spend the extra money and get an Ingersoll-Rand compressor. I had a Campbell-Hausfeld lasted about 4 months, piece of crap. My mom has my Craftsman about 6 years old, it sounds like it's about to go out, makes a really bad knocking noise. I bought the craftsman for airing up tires, and small impacts (1/4 and 3/8). I currently have a 7.5hp (25 cfm @ 175 psi) Ingersoll-Rand compressor, this compressor is a beast, takes about 5 minutes to air up a 20.8-38 tractor tire and it can do it all day long. My craftsman took about 30-45 minutes depending on how long its been running, this is what cause my craftsman to knock. When looking at a compressor make sure to get a two stage compressor becaue they have a continuous duty operation. |
| All times are GMT -5. The time now is 02:47 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
