Procharger Head Unit "J" Bracket Mount Bolt Ratchets
For those that are tired of dealing with the Procharger Head Unit to "J" bracket mount bolts. I have started to put a ratchet together, that is sure to make life much easier.
I know it has for me, no more fighting with a allen wrench. Here are 2 fine tooth ratchets, which work for the 1/4" and 5/16" Internal wrenching cap screws. I am sure you know what a pain it can be due to the sway bar being so close and only able to get a 1/4 turn at a time with the normal allen wrench.
Cost of the 2 ratchets to your door 26.00 shipped.....
PM or emails welcome
Thanks Chris
Thanks Chris
The hardest, most annoying, and most time consuming part of a pulley swap has to be dealing with the bracket mounting bolts. These tools simplify the process and are great for dealing with those bolts. The tools are solid and will definitely do the job required. I'd recommend that anyone who deals with a procharger to get these, they're definitely worth the money.
-Dan
-Dan
^^ thanks man do u know if both work one just cheaper than the other?? (for this application) i cant get the allen key in the bigger screw to get it out and was thinking about cutting the allen key down so it will fit between the sway bar
