LS1TECH - Camaro and Firebird Forum Discussion (https://ls1tech.com/forums/)
-   User Support & Resources (https://ls1tech.com/forums/user-support-resources-52/)
-   -   Can't edit signature (https://ls1tech.com/forums/user-support-resources/1336895-cant-edit-signature.html)
Paul 1953 Oct 1, 2010 07:58 PM
I'm just trying to change 30K to 46K in my sig. But I keep getting:
BB code size is not allowed
Thanks for help.
JeremyT Oct 1, 2010 08:49 PM
At some point, LS1Tech disabled BBCode size tag. You apparently had BBCode size tag in your signature before this change. In such an event, it's not until the user edits their signature will you then be required to comply with any changes that may have been made, permission wise.
You have BBCode size tags in your current signature:
[CENTER][SIZE="2"][SIZE="1"]Original owner '02 Z28 M6 Pewter 30K street miles only. Leather. Maxxgard coated finish. Standard suspension/chassis upgrades. Kooks LT, Catted Y, Corsa Catback. CNC TB.
Stock motor & wheels.[/SIZE][/SIZE] [/CENTER]
[CENTER][SIGPIC][/SIGPIC]
[SIZE="1"][/SIZE][/CENTER]
All those [size="x"][/size] are BBCode size tags that are no longer allowed.
In order to edit your signature, you will need to remove those tags. Unless an Administrator, such as Cragar, decides that BBCode Size tags are allowed again.
Thanks for help.
Paul 1953 Oct 2, 2010 07:48 AM
Ah ok thanks. I guess I'll just leave it as is.
© 2026 MH Sub I, LLC dba Internet Brands
